TI 公司的T
RF2443是高度集成全双工宽带无线IF收发器,接收器集成了IQ解调器,通过模拟和数字控制的VGA可提供大于90dB的增益,可编程的基带低通滤波器能灵活地接收不同带宽的信号,TX输出IP3为29.5dBm,TX输出噪音为-166dBc/Hz.TX信号链(165-175MHz / 330-350MHz),RX信号链(140-165MHz / 280-330MHz),主要应用在点对点微波,宽带无线接入,无线微波骨干线路和WiMAX IF收发器.本文介绍了T
RF2443的主要特性,功能方框图, 接收链路方框图, RX和TX PLL方框图, XPIC方框图, 应用电路图以及T
RF2443评估模块主要特性,电路图, 布局图(和所用材料清单.
Integrated IF Transceiver for Broadband Wireless Applications
T
RF2443 is a highly integrated full-duplex intermediate frequency (IF) transceiver designed for broadband point-to-point wireless communications applications. The receiver chain integrates a quadrature (IQ) demodulator and provides more than 90 dB of gain range, obtained via a combination of analog and digital controlled VGAs. The integrated programmable baseband low-pass filter gives the T
RF2443 the flexibility to receive signals with different bandwidths, while also helping to remove interferer signals before they reach the ADC. Additionally, the T
RF2443 gives the flexibility to add an external IF filter to further remove unwanted signals. The T
RF2443 transmitter chain integrates a quadrature (IQ) modulator driving a highly linear IF DVGA that provides 35 dB of gain range controlled via a serial programming interface (SPI). The T
RF2443 includes the two synthesizers for the receiver and transmitter chains, removing the need for external LO generation circuitry and simplifying the implementation of a frequency-division duplexing (FDD) transceiver design. The T
RF2443 also provides Cross-Polarization Interference Cancellation (XPIC) support via an integrated XPIC output amplifier and receiver chain. The T
RF2443 is an ideal building block for implementing the IF transceiver function in the Indoor Unit (IDU), which is connected via coaxial cable interface to the Outdoor Unit (ODU), of a point-to-point microwave backhaul split-architecture system.
T
RF2443主要特性:
Integrated TX Chain (165-175MHz / 330-350MHz)
Baseband Amplifiers
Quadrature Modulator
Digitally Controlled VGA
TX Output IP3: 29.5dBm
TX Output Noise: -166dBc/Hz
Integrated RX Chain (140-165MHz / 280-330MHz)
IF Amplifiers
Analog and Digital VGA
Quadrature Demodulator
Baseband Filters
ADC Buffers
IF SAW Filter Bypass
RX Noise Figure: 4.3dB
RX Input IP3: 9.5dBm
Integrated TX and RX Synthesizers
Integrated Cross-Polarization Interference Cancellation (XPIC) Support
Auxiliary RX Chain
T
RF2443应用:
Wireless Microwave Backhaul
Point-to-Point Microwave
WiMAX IF Transceiver
图1.T
RF2443功能方框图
图2.T
RF2443接收链路方框图
图3.T
RF2443 RX和TX PLL方框图
图4.T
RF2443 XPIC方框图
图5.T
RF2443应用电路图
T
RF2443 IF收发器评估模块
T
RF2443 Integrated IF Transceiver Evaluation Module
The T
RF2443EVM is the evaluation board for the T
RF2443 integrated IF transceiver for broadband wireless applications. The T
RF2443EVM includes instructions for equipment setup procedures, software GUI configurations, and test procedures that allow a user to quickly and accurately measure the T
RF2443 performance characteristics.The T
RF2443EVM can be used to select options for trimming the device configuration in order to meet various application requirements.
T
RF2443 评估模块主要特性:
Comprehensive test capability for the T
RF2443
USB connection from EVM to PC
Software support with a fully featured GUI for easy testing
T
RF2443 on-chip EEPROM access guide
图6.T
RF2443评估模块电路图(1)
图7.T
RF2443评估模块电路图(2)
图8.T
RF2443评估模块电路图(3)
图9.T
RF2443评估模块电路图(4)
图10.T
RF2443评估模块电路图(5)
图11.T
RF2443评估模块布局图(顶层)
材料清单:
