yuedx的个人空间 https://blog.eetop.cn/317611 [收藏] [复制] [分享] [RSS]
同步FIFO的Verilog代码
已有 4597 次阅读| 2009-10-25 22:39 |个人分类:FPGA设计基础知识
http://www.edabc.net/blog/?uid-20-action-viewspace-itemid-584
http://www.edabc.net/blog/?uid-26-action-viewspace-itemid-602
          A fifo controller verilog description.
module fifo_syn(datain,
                     rd,
                     wr,
                    rst,
                    clk,
                dataout,
                   full,
                   empty);
  input [7:0] datain;
  input rd, wr, rst, clk;
  output [7:0] dataout;
  output full, empty;
  reg [7:0] dataout;
  reg full_in, empty_in;
  reg [7:0] mem [15:0];
  reg [3:0] rp, wp;
  assign full = full_in;
  assign empty = empty_in;
  // memory read out         稍作修改
   always@(posedge clk) begin
    if(rd && ~empty_in) dataout = mem[rp];
  end
  // memory write in
    if(wr && ~full_in) mem[wp]<=datain;
  end
  // memory write pointer increment
  always@(posedge clk or negedge rst)
    if(!rst)
        wp<=0;
    else   wp <= (wr && ~full_in) ? (wp + 1'b1) : wp;
  // memory read pointer increment
    if(!rst)
       rp <= 0;
    else  rp <= (rd && ~empty_in)? (rp + 1'b1): rp;
  // Full signal generate
  always@(posedge clk or negedge rst) begin
    if(!rst) full_in <= 1'b0;
    else begin
      if( (~rd && wr)&&((wp==rp-1)||(rp==4'h0&&wp==4'hf)))
          full_in <= 1'b1;
      else if(full_in && rd) full_in <= 1'b0;
    end
  end
  // Empty signal generate
    if(!rst) empty_in <= 1'b1;
    else begin
      if((rd&&~wr)&&(rp==wp-1 || (rp==4'hf&&wp==4'h0)))
        empty_in<=1'b1;
      else if(empty_in && wr) empty_in<=1'b0;
    end
  end
endmodule
网上的代码读数据输出(dataout)部分不受读使能(rd)控制,显然不对,所以稍作修改,欢迎批评
另一种风格的同步FIFO
module FIFO_Buffer(
  Data_out,
  stack_full,
  stack_almost_full,
  stack_half_full,
  stack_almost_empty,
  stack_empty,
  Data_in,
  write_to_stack,
  read_from_stack,
  clk,rst
  parameter stack_width=32;
  parameter stack_height=8;
  parameter stack_ptr_width=3;
  parameter AE_level=2;
  parameter AF_level=6;
  parameter HF_level=4;
  output [stack_width-1:0] Data_out;
  output                 stack_full,stack_almost_full,stack_half_full;
  output                 stack_almost_empty,stack_empty;
  input[stack_width-1:0] Data_in;
  input                  write_to_stack,read_from_stack;
  input                  clk,rst;
  reg[stack_ptr_width-1:0] read_ptr,write_ptr;
  reg[stack_ptr_width:0]   ptr_gap;
  reg[stack_width-1:0]     Data_out;
  reg[stack_width-1:0]     stack[stack_height-1:0];
  assign stack_full=(ptr_gap==stack_height);
  assign stack_almost_full=(ptr_gap==AF_level);
  assign stack_half_full=(ptr_gap==HF_level);
  assign stack_almost_empty=(ptr_gap==AE_level);
  assign stack_empty=(ptr_gap==0);
  always @(posedge clk or posedge rst)
   if(rst)begin
       Data_out<=0;
       read_ptr<=0;
       write_ptr<=0;
       ptr_gap<=0;
   end
   else if(write_to_stack &&(!stack_full)&&(!read_from_stack))begin
       stack[write_ptr]<=Data_in;
       write_ptr<=write_ptr+1;
       ptr_gap<=ptr_gap+1;
   end
   else if((!write_to_stack)&&(!stack_empty)&&read_from_stack)begin
       Data_out<=stack[read_ptr];
       read_ptr<=read_ptr+1;
       ptr_gap<=ptr_gap-1;
   end
   else if(write_to_stack &&read_from_stack&&stack_empty)begin
       ptr_gap<=ptr_gap+1;
   end
   else if(write_to_stack &&read_from_stack&&stack_full)begin
       ptr_gap<=ptr_gap-1;
   end
   else if(write_to_stack&&read_from_stack&&(!stack_full)&&(!stack_empty))
   begin
   end
endmodule
显然这个比较容易理解
发表评论 评论 (4 个评论)
回复 wangxs 2009-11-20 13:18
顶! 不错!
回复 xinu2009 2010-4-9 10:30
研究一下子啊
回复 specterfj 2010-4-16 16:26
学习一下:loveliness:
回复 断桥残雪0114 2010-9-14 06:21
谢谢了,收藏一下~~~
  • 15
  • 1
  • 36
  • 158
  • 4703
GMT+8, 2025-4-8 03:59 , Processed in 0.011748 second(s), 9 queries , Gzip On, MemCached On.
