在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 110482|回复: 835
Razavi: Monolithic Phase-Locked Loops and Clock Recovery Circuits 全部论文集
发表于 2006-11-28 06:17:57 | 显示全部楼层 |阅读模式
Contents
PREFACE ix
Design of Monolithic Phase-Locked Loops and Clock Recovery Circuits-A Tutorial . . . . . . . . . . . . . . . . . . . . 1
B. Razavi (Original Paper).
PART 1 BASIC THEORY 41
Theory of AFC Synchronization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 43
W. J. Gruen (Proceedings of the IRE, August 1953).
Color-Carrier Reference Phase Synchronization Accuracy in NTSC Color Television . . . . . . . . . . . . . . . . . . . . 49
D. Richman (Proceedings of the IRE, January 1954).
Charge-Pump Phase-Locked Loops . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 77
F. M. Gardner (IEEE Transuctions on Communications, November 1980).
z-Domain Model for Discrete-Time PLLs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87
J. P. Hein and J. W. Scott (IEEE Transactions on Circuits and Systems, November 1988).
Analyze PLLs with Discrete Time Modeling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 94
J. Kovacs (Microwaves & RF: May 1991).
Properties of Frequency Difference Detectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 99
F. M. Gardner (IEEE Transactions on Communications, February 1985).
Frequency Detectors for PLLAcquisition in Timing and Carrier Recovery . . . . . . . . . . . . . . . . . . . . . . . . . . 107
D. G. Messerschmitt (IEEE Transuctions on Communicutions, September 1979).
Analysis of Phase-Locked Timing Extraction Circuits for Pulse Code Transmission . . . . . . . . . . . . . . . . . . . . . 115
E. Roza (IEEE Transactions on Communicutions, September 1974).
Optimization of Phase-Locked Loop Performance in Data Recovery Systems . . . . . . . . . . . . . . . . . . . . . . . . . 129
R. S. Co and J. H. Mulligan, Jr. (IEEE Journal of Solid-State Circuits, September 1994).
Noise Properties of PLL Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142
V. F. Kroupa (IEEE Transactions on Communications, October 1982).
PLLDLL System Noise Analysis for Low Jitter Clock Synthesizer Design . . . . . . . . . . . . . . . . . . . . . . . . . . 15 1
B. Kim, T. C. Weigandt, and P. R. Gray (Proceedings of the International Symposium on Circ~litsa nd
Systems, June 1994).
Practical Approach Augurs PLL Noise in RF Synthesizers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 155
M. O'Leary (Microwaves & RF: September 1987).
The Effects of Noise in Oscillators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 160
E. Hafner (Proceedings of the IEEE, February 1966)
A Simple Model of Feedback Oscillator Noise Spectrum . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 180
D. B. Leeson (Proceedings of the IEEE, February 1966).
Noise in Relaxation Oscillators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 182
A. A. Abidi and R. G. Meyer (IEEE Journal of Solid-State Circuits, December 1983).
Analysis of Timing Jitter in CMOS Ring Oscillators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 191
T. C. Weigandt, B. Kim, and P. R. Gray (Proceedings of the Iizrernarional Symposium on Circuits and
Analysis, Modeling, and Simulation of Phase Noise in Monolithic Voltage-Controlled Oscillators . . . . . . . . . . . . . . 195
B. Razavi (Proceedings of the Custom Integrated Circuits Conference, May 1995).
PART 2 BUILDING BLOCKS 199
Start-up and Frequency Stability in High-Frequency Oscillators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 201
N. M. Nguyen and R. G. Meyer (IEEE Journal of Solid-State Circuits, May 1992).
MOS Oscillators with Multi-Decade Tuning Range and Gigahertz Maximum Speed . . . . . . . . . . . . . . . . . . . . . 2 11
M. Banu (IEEE Journal of Solid-State Circuits, April 1988).
A Bipolar 1 GHz Multi-Decade Monolithic Variable-Frequency Oscillator . . . . . . . . . . . . . . . . . . . . . . . . . . 21 9
J. T. Wu (International Solid-State Circuit Conference Digest of Technical Papers, February 1991).
A Digital Phase and Frequency Sensitive Detector . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 222
J. I. Brown (Proceedings of the IEEE, April 197 1).
A 3-State Phase Detector Can Improve Your Next PLL Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 224
C. A. Sharpe (EDN Magazine, September 1976).
GaAs Monolithic PhaseRrequency Discriminator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 229
I. Shahriary et al. (IEEE Gallium Arsenide Integrated Circuits Symposium Digest of Technical
Papers, October 1985).
A New Phase-Locked Loop Timing Recovery Method for Digital Regenerators . . . . . . . . . . . . . . . . . . . . . . . 233
J. A. Bellisio (IEEE International Communications Conference Recording, June 1976).
A Phase-Locked Loop with Digital Frequency Comparator for Timing Signal Recovery . . . . . . . . . . . . . . . . . . . 237
J. A. Afonso, A. J. Quiterio, and D. S. Arantes (National Telecommunications Conference Recording, 1979).
Clock Recovery from Random Binary Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 242
J. D. H. Alexander (Electronics Letters, October 1975).
A Si Bipolar Phase and Frequency Detector IC for Clock Extraction up to 8 Gbls . . . . . . . . . . . . . . . . . . . . . . . 244
A. Pottbacker, U. Langmann, and H. U. Schreiber (IEEE Journal of Solid-State Circuits,
December 1992).
A Self-correcting Clock Recovery Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 249
C. R. Hogge (IEEE Journal of Lightwave Technology, December 1985).
PART 3 MODELING AND SIMULATION 253
An Integrated PLL Clock Generator for 275 MHz Graphic Displays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 255
G. Gutierrez and D. DeSimone (Proceedings of the Custom Integrated Circuits Conference, May 1990).
The Macro Modeling of Phase-Locked Loops for the SPICE Simulator . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 59
M. Sitkowski (IEEE Circuits and Devices Magazine, March 1991).
Modeling and Simulation of an Analog Charge Pump Phase-Locked Loop . . . . . . . . . . . . . . . . . . . . . . . . . . 264
S. Can and Y. E. Sahinkaya (Simulation, April 1988).
Mixed-Mode Simulation of Phase-Locked Loops . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 270
B. A. A. Antao, F. M. El-Turky, and R. H. Leonowich (Proceedings of the Custom Integrated
Circuits Conference, May 1993).
Behavioral Represertstion for VCO and Detectors in Phase-Lock Systems . . . . . . . . . . . . . . . . . . . . . . . . . . 274
E. Liu and A. L. Sangiovanni-Vincentelli (Proceedings of the Custom Integrated Circuits
Conference, May 1992).
Behavioral Simulation Techniques for PhaseIDelay-Locked Systems . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 278
A. Demir, E. Liu, and A. L. Sangiovanni-Vincentelli (Proceedings of the Custom Integrated Circuits
Conference, May 1994).
PART 4 PHASE-LOCKED LOOPS 283
A Monolithic Phase-Locked Loop with Detection Processor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 285
E. N. Murthi (IEEE Journal of Solid State Circuits, February 1979).
A 200-MHz CMOS Phase-Locked Loop with Dual Phase Detectors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 292
K. M. Ware, H.-S. Lee, and C. G. Sodini (IEEE Journal of Solid-State Circuits, December 1989).
High-Frequency Phase-Locked Loops in Monolithic Bipolar Technology . . . . . . . . . . . . . . . . . . . . . . . . . . . 301
M. Soyuer and R. G. Meyer (IEEE Journal of Solid-State Circuits, June 1989).
A 6-GHz Integrated Phase-Locked Loop Using AlGaAsIGaAs Heterojunction Bipolar Transistors . . . . . . . . . . . . . . 3 10
A. W. Buchwald, et al. (IEEE Journal of Solid-State Circuits, December 1992).
A 6-GHz 60-mW BiCMOS Phase-Locked Loop with 2-V Supply . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 320
B. Razavi and J. Sung (IEEE Journal of Solid-State Circuits, December 1994).
Design of PLL-Based Clock Generation Circuits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 326
D. K. Jeong, et al. (IEEE Journal of Solid-State Circuits, April 1987).
A Variable Delay Line PLL for CPU-Coprocessor Synchronization . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 333
M. G. Johnson and E. L. Hudson (IEEE Journal of Solid-State Circuits, October 1988).
A PLL Clock Generator with 5 to 11 0 MHz of Lock Range for Microprocessors . . . . . . . . . . . . . . . . . . . . . . . 339
I. A. Young, J. K. Greason, and K. L. Wong (IEEE Journal of Solid-State Circuits, November 1992).
A Wide-Bandwidth Low-Voltage PLL for PowerPC Microprocessors . . . . . . . . . . . . . . . . . . . . . . . . . . . . .3 47
J. Alvarez"", et al. (IEEE Journal of Solid-State Circuits, April 1995).
A 30-128 MHz Frequency Synthesizer Standard Cell . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 355
R. F. Bitting and W. P. Repasky (Proceedings of the Custom Integrated Circuits Conference, May 1992).
Cell-Based Fully Integrated CMOS Frequency Synthesizers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361
D. Mijuskovic, et al. (IEEE Journal of Solid-State Circuits, March 1994).
Fully-Integrated CMOS Phase-Locked Loop with 15 to 240 MHz Locking Range and +SO psec Jitter . . . . . . . . . . . . 369
I. Novof, et al. (International Solid-State Circuit Conference Digest of Technical Papers, February 1995).
PLL Design for a 500 MBIs Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 377
M. Horowitz, et al. (International Solid-State Circuit Conference Digest of Technical Papers, February 1993).
PART 5 CLOCK AND DATA RECOVERY CIRCUITS 381
An Analog PLL-Based Clock and Data Recovery Circuit with High Input Jitter Tolerance . . . . . . . . . . . . . . . . . . 383
S. Y. Sun (IEEE Journal of Solid-State Circuits, April 1989).
A 30-MHz Hybrid AnalogDigital Clock Recovery Circuit in 2-ym CMOS . . . . . . . . . . . . . . . . . . . . . . . . . . 389
B. Kim, D. N. Helman, and P. R. Gray (IEEE Journal of Solid-State Circuits, December 1990).
A BiCMOS PLL-Based Data Separator Circuit with High Stability and Accuracy . . . . . . . . . . . . . . . . . . . . . . 399
S. Miyazawa, et al. (IEEE Journal of Solid-State Circuits, February 1991).
A Versatile Clock Recovery Architecture and Monolithic Implementation . . . . . . . . . . . . . . . . . . . . . . . . . . . 405
L. De Vito (Invited Paper).
A 155-MHz Clock Recovery Delay- and Phase-Locked Loop . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 42 1
T. H. Lee and J. F. Bulzacchelli (IEEE Journal of Solid-State Circuits, December 1992).
A Monolithic 156 Mbls Clock and Data Recovery PLL Circuit using the Sample-and-Hold Technique . . . . . . . . . . . 43 1
N. Ishihara and Y. Akazawa (IEEE Journal of Solid-State Circuits, December 1994).
A Monolithic 480 Mbls Parallel AGC/Decision/Clock Recovery Circuit in 1.2-ym CMOS . . . . . . . . . . . . . . . . . . 437
T. H. Hu and P. R. Gray (IEEE Journal of Solid-State Circuits, December 1993).
A Monolithic 622 Mblsec Clock Extraction and Data Retiming Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . 444
B. Lai and R. C. Walker (International Solid-State Circuit Conference Digest of Technical Papers,
February 199 1).
A 660 Mbls CMOS Clock Recovery Circuit with Instantaneous Locking for NRZ Data and Burst-
Mode Transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 447
M. Banu and A. Dunlop (International Solid-State Circuit Conference Digest of Technical Papers,
February 1993).
AMonolithic 2.3-Gbls 100-mW Clock and Data Recovery Circuit in Silicon Bipolar Technology . . . . . . . . . . . . . . 450
M. Soyuer (IEEE Journal of Solid-State Circuits, December 1993).
A 50 MHz Phase- and Frequency-Locked Loop . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 454
R. R. Cordell, et al. (IEEE Journal of Solid-State Circuits, December 1979).
NMOS ICs for Clock and Data Regeneration in Gigabit-per-Second Optical-Fiber Receivers . . . . . . . . . . . . . . . . 461
S. K. Enam and A. A. Abidi (IEEE Journal of Solid-State Circuits, December 1992).
A PLL-Based 2.5-Gbls Clock and Data Regenerator IC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 473
H. Ransijn and P. O'Connor (IEEE Journal of Solid-State Circuits, October 1991).
A 2.5-Gblsec 15-mW BiCMOS Clock Recovery Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 481
B. Razavi and J. Sung (Symposium on VLSI Circuits Digest of Technical Papers, 1995).
An 8 GHz Silicon Bipolar Clock Recovery and Data Regenerator IC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 483
A. Pottbacker and U. Langmann (IEEE Journal of Solid-State Circuits, December 1994).
 楼主| 发表于 2006-11-28 06:21:19 | 显示全部楼层
part 1
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part01.rar
1.91 MB, 下载次数: 2244 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-28 06:22:13 | 显示全部楼层
part 2
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part02.rar
1.91 MB, 下载次数: 1848 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-28 06:23:19 | 显示全部楼层
part 3
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part03.rar
1.91 MB, 下载次数: 1672 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-28 06:23:55 | 显示全部楼层
part 4
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part04.rar
1.91 MB, 下载次数: 1351 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-28 06:24:35 | 显示全部楼层
part 5
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part05.rar
1.91 MB, 下载次数: 1739 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-28 06:25:34 | 显示全部楼层
part 7
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part07.rar
1.91 MB, 下载次数: 1538 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-28 06:26:18 | 显示全部楼层
part 8
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part08.rar
1.91 MB, 下载次数: 1685 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-28 06:27:27 | 显示全部楼层
part 6
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part06.rar
1.91 MB, 下载次数: 1502 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2006-11-28 06:28:00 | 显示全部楼层
part 9
Razavi_Monolithic_Phase-Locked_Loops_and_Clock_Recovery_Circuits.part09.rar
1.91 MB, 下载次数: 1752 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-5-6 17:47 , Processed in 0.033692 second(s), 8 queries , Gzip On, MemCached On.
