在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 101197|回复: 638
新书!The gm/ID Methodology, a sizing tool for low-voltage analog CMOS Circuits
发表于 2009-12-5 09:20:57 | 显示全部楼层 |阅读模式
[size=120%]The gm/ID Methodology, a sizing tool for low-voltage analog CMOS Circuits: The semi-empirical and compact model approaches (Analog Circuits and Signal Processing)
By Paul G.A. Jespers
  • Publisher:   Springer
  • Number Of Pages:   225
  • Publication Date:   2009-12
  • ISBN-10 / ASIN:   0387471006
  • ISBN-13 / EAN:   9780387471006
Product Description:
In "The gm/ID Methodology, a Sizing Tool for Low-Voltage Analog CMOS Circuits", we compare the semi-empirical to the compact model approach. Small numbers of parameters make the compact model attractive for the model paves the way towards analytic expressions unaffordable otherwise. The E.K.V model is a good candidate, but when it comes to short channel devices, compact models are either inaccurate or loose straightforwardness. Because sizing requires basically a reliable large signal representation of MOS transistors, we investigate the potential of the E.K.V model when its parameters are supposed to be bias dependent. The model-driven and semi-empirical methods are compared considering the Intrinsic Gain Stage and a few more complex circuits. A series of MATLAB files contained in the CD-ROM allow redoing the tests.
The gm_ID Methodology, a sizing tool for low-voltage analog CMOS Circuits.rar
2.58 MB, 下载次数: 7315 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-12-5 09:25:49 | 显示全部楼层
很好,谢谢,顶一个
发表于 2009-12-5 09:26:51 | 显示全部楼层
thanks for sharing
发表于 2009-12-5 09:27:18 | 显示全部楼层
我也加入模拟大军了 哈哈 从头学起
发表于 2009-12-5 10:06:39 | 显示全部楼层
楼主威武
发表于 2009-12-5 10:55:57 | 显示全部楼层
bucuo1111
发表于 2009-12-5 11:05:36 | 显示全部楼层
6# welin
qqqqqqqqqqqqqqqqqqqqqq
发表于 2009-12-5 12:30:34 | 显示全部楼层
gm/ID, 不错的设计方法
发表于 2009-12-5 12:32:34 | 显示全部楼层
bu cuo bu cuo
发表于 2009-12-5 13:27:27 | 显示全部楼层
thank you very much!
GMT+8, 2025-4-5 08:58 , Processed in 0.028448 second(s), 8 queries , Gzip On, MemCached On.
