在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 12068|回复: 39
火热出炉的JSSC20093月paper全集
发表于 2009-3-2 00:51:49 | 显示全部楼层 |阅读模式
1、Multi-Standard Mobile Broadcast Receiver LNA With Integrated Selectivity and Novel Wideband Impedance Matching Technique
2、A Wideband CMOS Low Noise Amplifier Employing Noise and IM2 Distortion Cancellation for a Digital TV Tuner
3、A 2.4–2.5 GHz WLAN Direct-Conversion Receiver Front-End With Low-Distortion Baseband Filters
4、A 60 kb/s–10 Mb/s Adaptive Frequency Hopping Transceiver for Interference-Resilient Body Channel Communication
5、A Single–Chip 10-Band WCDMA/HSDPA 4-Band GSM/EDGE SAW-less CMOS Receiver With DigRF 3G Interface and ${+}$90 dBm IIP2
6、A 1.2 V 114 mW Dual-Band Direct-Conversion DVB-H Tuner in 0.13 $mu$ m CMOS
7、A New Transceiver Architecture for the 60-GHz Band
8、A 125–1250 MHz Process-Independent Adaptive Bandwidth Spread Spectrum Clock Generator With Digital Controlled Self-Calibration
9、A 33.6-to-33.8 Gb/s Burst-Mode CDR in 90 nm CMOS Technology
10、Analysis and Design of a CMOS Phase-Tunable Injection-Coupled LC Quadrature VCO (PTIC-QVCO)
11、An LC-Based Clock Buffer With Tunable Injection Locking
12、Distributed Waveform Generator: A New Circuit Technique for Ultra-Wideband Pulse Generation, Shaping and Modulation
13、A 3 GHz Fractional All-Digital PLL With a 1.8 MHz Bandwidth Implementing Spur Reduction Techniques
14、Laser Radar Receiver Channel With Timing Detector Based on Front End Unipolar-to-Bipolar Pulse Shaping
15、A 1.2 GSample/s Double-Switching CMOS THA With ${- }$62 dB THD
16、A 32 mW 1.25 GS/s 6b 2b/Step SAR ADC in 0.13$ mu$m CMOS
17、A 2.2 mW 1.75 GS/s 5 Bit Folding Flash ADC in 90 nm Digital CMOS
18、A 10-bit 50 MS/s Pipelined ADC With Capacitor-Sharing and Variable-$g_{m}$ Opamp
19、A 2.7 mW, 90.3 dB DR Continuous-Time Quadrature Bandpass Sigma-Delta Modulator for GSM/EDGE Low-IF Receiver in 0.25 $mu$m CMOS
20、A 4.8 GS/s 5-bit ADC-Based Receiver With Embedded DFE for Signal Equalization
21、A 0.8 V, 2.6 mW, 88 dB Dual-Channel Audio Delta-Sigma D/A Converter With Headphone Driver
22、Output Impedance Shaping for Frequency Compensation of MOS Audio Power Amplifiers
23、Low-Power Race-Free Programmable Logic Arrays
24、A High-Speed Inductive-Coupling Link With Burst Transmission
25、Design of Power-Rail ESD Clamp Circuit With Ultra-Low Standby Leakage Current in Nanoscale CMOS Technology
26、Design of Sub-90 nm Low-Power and Variation Tolerant PD/SOI SRAM Cell Based on Dynamic Stability Metrics
27、Synchronous Ultra-High-Density 2RW Dual-Port 8T-SRAM With Circumvention of Simultaneous Common-Row-Access
28、A Process Variation Tolerant Embedded Split-Gate Flash Memory Using Pre-Stable Current Sensing Scheme
29、256-Channel Neural Recording and Delta Compression Microsystem With 3D Electrodes
30、A Biomimetic, 4.5 $mu$W, 120+ dB, Log-Domain Cochlea Channel With AGC
 楼主| 发表于 2009-3-2 00:57:33 | 显示全部楼层
开始了
1
JSSC2009.03.part01.rar
4.39 MB, 下载次数: 186 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.03.part02.rar
4.39 MB, 下载次数: 176 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2009-3-2 01:15:25 | 显示全部楼层
2
JSSC2009.03.part03.rar
4.39 MB, 下载次数: 163 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.03.part04.rar
4.39 MB, 下载次数: 155 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.03.part05.rar
4.39 MB, 下载次数: 151 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.03.part06.rar
4.39 MB, 下载次数: 152 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.03.part07.rar
4.39 MB, 下载次数: 148 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.03.part08.rar
JSSC2009.03.part09.rar
4.39 MB, 下载次数: 147 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2009.03.part10.rar
JSSC2009.03.part11.rar
2.11 MB, 下载次数: 151 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-3-2 02:30:16 | 显示全部楼层
thanks for sharing~~
 楼主| 发表于 2009-3-2 09:28:49 | 显示全部楼层
自己顶下
发表于 2009-3-2 14:42:26 | 显示全部楼层
 楼主| 发表于 2009-3-2 21:03:57 | 显示全部楼层
:handshake
发表于 2009-3-5 09:05:49 | 显示全部楼层
Thanks!
发表于 2009-3-5 10:32:01 | 显示全部楼层
goooooooood
发表于 2009-3-5 11:05:29 | 显示全部楼层
That's a good stuff. Thank you for sharing.
GMT+8, 2025-5-7 07:12 , Processed in 0.039902 second(s), 7 queries , Gzip On, MemCached On.
