在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 44252|回复: 363
【Wiley 2007 新书】Phase-Lock Basics, Second Edition
发表于 2008-8-4 21:05:12 | 显示全部楼层 |阅读模式
[size=120%]Phase-Lock Basics, Second Edition
By William F. Egan
  • Publisher:   Wiley-IEEE Press
  • Number Of Pages:   441
  • Publication Date:   2007-11-02
  • ISBN-10 / ASIN:   0470118008
  • ISBN-13 / EAN:   9780470118009
  • Binding:   Hardcover
Product Description:
Broad-based and hands-on, Phase-Lock Basics, Second Edition is both easy to understand and easy to customize. The text can be used as a theoretical introduction for graduate students or, when used with MATLAB simulation software, the book becomes a virtual laboratory for working professionals who want to improve their understanding of the design process and apply it to the demands of specific situations. This second edition features a large body of new statistical data obtained from simulations and uses available experimental data for confirmation of the simulation results.
Summary: Good treatment of core subject, but difficult for beginner
Rating: 4
I am new to phase-lock loop design. Like most recent EE grads, I had one class in linear control systems, and some basic DSP classes, but thankfully that's enough to get started on PLL design. I haven't finished Egan's book, but so far I think I can make some generalizations about his writing style. He redefines some 'common concepts' (like frequency) as "frequency + phase." You have to read carefully, otherwise you might miss his redefinition, and that will cause you confusion for the rest of the book. I don't like how he simply writes down formulas without any kind of symbol explanation. He explains the formulas well, but a simple 'w_c = carrier frequency component, f_m = modulation frequency component' alongside the formulas would really help. Symbols are re-used quite often, so one variable may change meaning from one page to the next...This means you can't just skip around the book without carefully reading the accompanying text passages. These minor annoyances aside, the content is excellent. He spends a little time covering "basic material", for example bode-plots, root-locus, nyquist plots, and shows how these basic tools can aide a qualitative understanding of PLL steady-state stability. (Everything is cast as a second-order system, which is easy to hand-decompose.) This is important, because once you read about the non-linear regions of PLL behavior, it's easy to get lost in the math.
Summary: Excellent Book
Rating: 5
This is my favorite book on phase locked loops in my entire library. It is an excellent book for actually learning phase locked loops from the ground up. I have been involved in PLL design for four years. Reading through this book last year provoked a series of, "Aha!" moments and "That's an excellent way to phrase that," comments. Egan has the knack of taking concepts which should be familiar to anyone with a degree in electrical engineering, and extending them easily to the very specific study of phase locked loop systems. His writing is clear and straight forward, and his analogies and examples are well chosen. And happily, he does NOT make use of the age-old (and incomprehensibly useless to most of us) mechanical damping or servo systems. This should be the first book on PLLs you read. Then you can move on to Rohde, et al.
[ 本帖最后由 benemale 于 2008-8-4 21:08 编辑 ]
Phase-Lock Basics, Second Edition.part1.rar
3.66 MB, 下载次数: 2233 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Phase-Lock Basics, Second Edition.part2.rar
3.62 MB, 下载次数: 2089 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-8-4 21:24:12 | 显示全部楼层
好书,谢谢
发表于 2008-8-4 21:30:56 | 显示全部楼层
thanks for your information..........................
thanks..........................................................
发表于 2008-8-4 22:36:09 | 显示全部楼层
谢谢楼主,好东东啊!!!!!!!!!!!!
发表于 2008-8-4 22:43:25 | 显示全部楼层
发表于 2008-8-4 22:45:19 | 显示全部楼层
basics pll 還得了五顆新感謝你的分享
发表于 2008-8-4 23:55:48 | 显示全部楼层
谢谢楼主,好东东
发表于 2008-8-5 01:57:36 | 显示全部楼层
Thanks
发表于 2008-8-5 02:06:44 | 显示全部楼层
thanks
发表于 2008-8-5 02:10:03 | 显示全部楼层
thanks
GMT+8, 2025-4-3 21:42 , Processed in 0.030133 second(s), 8 queries , Gzip On, MemCached On.
